configure igmp snooping vlan ports add dynamic group
configure igmp snooping {vlan} vlan_name {ports portlist} add dynamic group [ grpipaddress ]
Description
Configures an IGMP dynamic group.
Syntax Description
vlan_name Specifies a vlan name.
portlist Specifies a port list.
grpipaddress Specifies the multicast group IP address.
Default
N/A.
Usage Guidelines
This command adds IGMP groups to specific VLANs or to ports belonging to specific VLANs. After the groups are added, the expiration timer is started. This causes the groups to expire. The configuration is not saved in the configuration file. The following message is displayed on execution of this command:
INFO: This command is not saved in the configuration.
The following example adds a dynamic group to a switch port:
switch.111 # configure igmp snooping vlan "ixia113" ports 47 add dynamic group 225.1.1.1
The following command displays the group:
switch.112 # show igmp group
Group Address     Ver Vlan            Port     Age
225.1.1.1         2   ixia113         47       3
Total: 1
switch.113 #
The following example adds a dynamic group to a vlan (loopback port):
switch sw5.113 # configure igmp snooping vlan "ixia113" add dynamic group 225.1.1.1
switch.114 # show igmp group
225.1.1.1         2   ixia113         Lpbk     37
Total: 1
switch.115 #
This command was first available in ExtremeXOS 15.3.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
